G4 Challenge LogoLand Rover G4 Challenge Owners Club
Home Search Tags Calendar
diff needed
Posted By phil worrall 2 Jul 2010
Add to Favorites0
Author Message
phil worrall
 Posted 2 Jul 2010
Supreme Being
Supreme Being - (749 reputation)Supreme Being - (749 reputation)Supreme Being - (749 reputation)Supreme Being - (749 reputation)Supreme Being - (749 reputation)Supreme Being - (749 reputation)Supreme Being - (749 reputation)Supreme Being - (749 reputation)Supreme Being - (749 reputation)
Group: Club Member
Last Active: 4 hours ago
Posts: 305, Visits: 5,991
749
hi a recent trip to buildwas with Alan and Brendan although great fun thanks to them (still dont believe brendan went up that huge hill in reverse lol did you ever get photos) as mine ended up being towed back to camp with broken rear diff hence this post does anyone know where i can get a 4 pin 12 spline rear diff land rover part TBB 000270 or an exchange unit which could be LRO 06047 any advice or help would be great thanks
regards phil
BT52 OVB
2002 110 defender
west midlands 4x4 response
WM16
bumpy
 Posted 3 Jul 2010
Forum Guru
Forum Guru - (87 reputation)Forum Guru - (87 reputation)Forum Guru - (87 reputation)Forum Guru - (87 reputation)Forum Guru - (87 reputation)Forum Guru - (87 reputation)Forum Guru - (87 reputation)Forum Guru - (87 reputation)Forum Guru - (87 reputation)
Group: Forum Only
Last Active: 28 Apr 2011
Posts: 25, Visits: 244
87
From my poor memory --the post 02 110 rear axle has the bolt configuration of a P38 but has a long nose of the defender range instead of the P38 short nose.... therefore its a one off....it is a 4 pin type diff.
you see them on ebay
http://cgi.ebay.co.uk/LAND-ROVER-DEFENDER-late-2002-on-110-rear-differential-/290406989802?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item439d9affea
alternatively..buy one from Ashcroft transmissions
http://www.ashcroft-transmissions.co.uk/index.php?act=viewCat&catId=8
or get your old one reconditioned by Crown Diffs
http://www.crowndiffs.co.uk/diffs.html#recon_diffs
Kam diffs are very good --and they also make their own 4 pin centres.
http://www.kamdiffs.com/four_by_four.php?l=4_Pin_Diff&link=4_Pin_Diff442
Majority of diff failures are people spinning the wheels too much--when the tyre decides to get grip the plant wheels explode or pins break.... this is why standard cars [defender/disco] have 2 pin and more powerful vehicles have 4 pins--they came out after the V8 90 was launched in mid-80's...and the army had them fitted to 90's on the front line.
The other problem with powerful engines --the crown wheel is pushed out due to the torque and breaks the teeth on the crown wheel-- this is why diffs get 'pegged' --its a brass slipper plate which holds the crown wheel into the pinion drive so it cant bend out.
I knew 4 years of racing a Bowler Wildcat would come in useful on this forum :)
[dont get hung up on the 12 spline diff-- 24 spine shafts and drive members are cheap as chips]
MikeS
 Posted 3 Jul 2010
Supreme Being
Supreme Being - (720 reputation)
Group: Club Member
Last Active: Yesterday @ 1:15 PM
Posts: 219, Visits: 875
720
Ashcrofts are the people, wouldn't bother with anyone else tbh. Had a diff from my P38 done by them, pretty much 48hr turnround.
BV55 YZE, Fleet No 19 - Thailand 2006
Now registered as YZE 481 in Melbourne, Oztralia.
phil worrall
 Posted 6 Jul 2010
Supreme Being
Group: Club Member
749
Thanks for your help guys Hope to get her fixed soon
regards phil
BT52 OVB
2002 110 defender
WM16
Brendan
 Posted 6 Jul 2010
Supreme Being
Supreme Being - (590 reputation)Supreme Being - (590 reputation)Supreme Being - (590 reputation)Supreme Being - (590 reputation)Supreme Being - (590 reputation)Supreme Being - (590 reputation)Supreme Being - (590 reputation)Supreme Being - (590 reputation)Supreme Being - (590 reputation)
Last Active: Yesterday @ 10:35 PM
Posts: 254, Visits: 2,945
590
hi phill
i spoke to my man who breaks landrovers, no diffs to suit yours.  Says you may be better to go for a reconditioned one as cost is similar.
Hope this helps
Bren
Brendan
G4OC Travel officer
G4D3 08
3.9 V8 D1
2.5 D 90
phil worrall
 Posted 24 Jul 2010
Supreme Being
Group: Club Member
749
Thanks for all your help first worries tuned out to be wrong though in the end I needed a pair of half shafts and drive flanges all parts came to £120 from mm 4x4 worcester we are now all having fun in Blackpool thanks again to everone
regards phil
BT52 OVB
2002 110 defender
WM16
Expand / Collapse
Expand / Collapse
Back To Top
